Introduction : when we start the ap it will obtain the ip address from the dhcp server and finds the master.if we need to bring up an ap without dhcp server we can do so by assinging the static parameters. Following commands will help to assing static address on ap
Environment : Will apply to all Aruba Campus APs
Configuration Steps :
How to set static parameters in AP
We need to suspend the autoboot while the AP is booting using the enter command
Then the AP will go into apboot mode
For assigning the static parameters
apboot>setenv ipaddr <IP>
apboot>setenv gatewayip <GW>
apboot>setenv netmask <MASK>
apboot>setenv remote_ap 1
apboot>setenv master <IP controller>
To delay the boot time :
apboot> setenv delayboot <seconds>
To save the config
apboot>save
To reset the ap
apboot>purge
To reboot the ap
apboot>boot
