How to audit trail all commands which were running in Controller?
Question: How to audit trail all commands which were running in Controller?
By default, audit trail is enabled for all commands in configuration mode. Use the show audit-trail command to
display the content of the audit trail.
For example:
(Master) (config) #show audit-trail 5
Sep 28 10:59:24  fpcli: USER:admin@10.240.104.110 COMMAND:<wlan ssid-profile "temp-ssid" > -- command executed successfully
Sep 28 10:59:27  fpcli: USER:admin@10.240.104.110 COMMAND:<wlan ssid-profile "temp-ssid" essid "temp" > -- command executed successfully
Sep 28 10:59:35  fpcli: USER:admin@10.240.104.110 COMMAND:<wlan virtual-ap "temp-vap" > -- command executed successfully
Sep 28 10:59:40  fpcli: USER:admin@10.240.104.110 COMMAND:<wlan virtual-ap "temp-vap" ssid-profile "temp-ssid" > -- command executed successfully
Sep 28 10:59:48  fpcli: USER:admin@10.240.104.110 COMMAND:<wlan virtual-ap "temp-vap" vlan "4" > -- command executed successfully
Enable "audit-trail all" will include all commands in configuration mode and enable mode.
For example:
(Master) #show audit-trail 10
Sep 28 11:08:47  fpcli: USER:admin@10.240.104.110 COMMAND:<dir > -- command executed successfully
Sep 28 11:08:51  fpcli: USER:admin@10.240.104.110 COMMAND:<show ap essid > -- command executed successfully
Sep 28 11:09:34  fpcli: USER:admin@10.240.104.110 COMMAND:<dir > -- command executed successfully
Sep 28 11:11:07  fpcli: USER:admin@10.240.104.110 COMMAND:<copy flash: "default.cfg" flash: "default-bak.cfg" > -- command executed successfully
Sep 28 11:12:14  fpcli: USER:admin@10.240.104.110 COMMAND:<show wlan ssid-profile > -- command executed successfully
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 05:10 PM
Labels (1)
Contributors
