How to check and verify the statistics of WIFI radio debug logs on AP?
MVP
MVP
Q:
A:
Yes; we could verify the statistics of WIFI radio debugs for the specific AP by the below command “show ap debug radio-info ap-name <name of the ap> radio <0/1>
(Aruba) #show ap debug radio-info ap-name AP-225 radio 0
Radio Info Script
aruba_dbg_radio_info_0 Start time: Fri Mar 27 14:33:21 IST 2015
wifi0-drop-list:
_dma_rxreclaim(1633): 2520/2520 0/0
wlc_recvctl(44993): 3130421/3130421 0/0
wlc_dotxstatus(41101): 2502/2502 2502/2502
Note: This command is applicable only 200 series AP`s like AP 200,210,220 and 270`s.
Use case:
•    Command would help to understand radio debug logs and verify the drop on wireless.
•    Earlier this command was available only from AP shell mode to see drop like on AP radio.
•    This command output is introduced from 6.4.2.6 and above.
Version history
Revision #:
2 of 2
Last update:
‎07-16-2015 04:46 AM
Updated by:
Labels (1)
Contributors
Comments
mumtaz8271
How to check Access point logs in Mobility Controller ( Web ) with any Command
