How to check if 802.11b protection mode is enabled on Access Point (AP)?
When 802.11 b protection is enabled, its allow 802.11b station to associate to the Access Point (AP).
To check the configured value, type the following command from the CLI.
(Aruba2400) #show ap details ip-addr | include 802.11b
802.11b Protection Enabled Configuration
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 09:22 AM
Updated by:
Labels (1)
