How to check if a Managed Device(MD) has recovered from a bad configuration on Mobility Master(MM)?
MVP
MVP
Q:
A:
Mobility Master indicates if a device has recovered from a bad configuration through the "show switches" command output. The output for this command labels the "Configuration State" for the managed device as "CONFIG  ROLLBACK" if the device has recovered connectivity using the rollback configuration.
When the user fixes the bad configuration on Mobility Master, the managed device recovers automatically, and the state changes to ‘UPDATE SUCCESSFUL’.
Example output for the show switches command:
(Aruba-MM) [mynode] #show switches
All Switches
IP Address     IPv6 Address  Name              Location          Type    Model      Version        Status  Configuration State  Config Sync Time (sec)  Config ID
10.17.164.179  None          Aruba-MM  Building1.floor1  master  ArubaMM    8.0.1.0_57204  up      UPDATE SUCCESSFUL    0                       5
10.17.169.151  None          Aruba-MD  Building1.floor1  MD      Aruba7240  8.0.1.0_57204  up      CONFIG ROLLBACK      0                       4
Total Switches:2
Version history
Revision #:
1 of 1
Last update:
‎03-21-2017 12:49 PM
Updated by:
