How to check if an AP is running out of TX buffers which leads to dropped packets?
Run the following command per AP and radio band to check for available TX buffers:
#show ap debug radio-stats ap-name <ap_name> radio 0 advanced | inc Buffer
# show ap debug radio-stats ap-name <ap_name> radio 1 advanced | inc Buffer
Examples:
* Normal AP125 operation:
(mm6000-M3) #show ap debug radio-stats ap-name M3-ap125-1 radio 0 advanced | include Buffer
Avail TX Buffers          512
Dropped No Buffer         0
* AP running out of buffers:
(mm6000-M3) # show ap debug radio-stats ap-name M3-ap125-2 radio 0 advanced | include Buffer
Avail TX Buffers          14
Dropped No Buffer         1007
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 02:35 PM
Updated by:
Labels (1)
Contributors
