How to clear port statistics on an Aruba Controller.
MVP
MVP
Q:
What is the command to clear the port statistics on an Aruba Controller?
A:
In some situation port statistics will help in identifying the amount of traffic flow as well as the errors that occur. If we need to measure the traffic flow or count the errors that happen,
We may need to reset the statistics and observe the behavior in such scenarios.
We can use below commands to reset the statistics of the port on Aruba Controller.
Version history
Revision #:
2 of 2
Last update:
‎03-07-2016 12:01 PM
Updated by:
Labels (1)
Contributors
