How to clear the device IDs cached on the controller?
MVP
MVP
Q:
A:
Use the following command to the device id cache.
clear aaa device-id-cache <all | mac>
Example:
(Aruba) #show aaa device-id-cache | include Entries
Device ID Cache Entries : 3094
Command to clear the device IDs cached:
(Aruba) #clear aaa device-id-cache ?
all                     Clear all entries in the device ID cache
mac                  Clear entry in the device ID cache for MAC address
(Aruba) #clear aaa device-id-cache all
Device ID Cache Entries : 0
This is tested on a 7210 controller running Aruba OS 6.4.2.3.
Version history
Revision #:
2 of 2
Last update:
‎04-07-2015 02:11 PM
Updated by:
Labels (1)
Contributors
Tags (1)
