AP 225 support for Link Aggregation is introduced from AOS 6.3.1. This helps in using of both the uplinks of AP 225 in sending traffic to the controller.
one uplink will be used for a radio. That is Eth0 for 5GHz radio and Eth1 for 2.4Ghz radio.
Network Topology : The architecture of the solution.
To enable this configuration, in the AP system profile a new parameter called "GRE Striping IP" has to be configured. This has to be LMS IP +1.
Ensure that IP address based load balancing is enabled for all LAGs from AP to controller.
