How to configure Airmatch to set static configuration in an ArubaMM?
MVP
MVP
In some situations just to limit the coverage of the Access Point and on a specific channel.
We can configure Airmatch to set the static value for transmit power/channel when needed and below is the configuration.
To set static configuration:
(ArubaMM) [mynode] #
(ArubaMM) [mynode] #airmatch ap freeze ap-name AP1 eirp 12 band 2ghz channel 11
(ArubaMM) [mynode] #airmatch ap freeze ap-name AP1 eirp 12 band 5ghz channel 36
To remove static configuration:
(ArubaMM) [mynode] (config) #airmatch ap unfreeze ap-name AP1 band 2ghz eirp
(ArubaMM) [mynode] (config) #airmatch ap unfreeze ap-name AP1 band 5ghz eirp
Command to verify the static configuration:
(ArubaMM) [mynode] (config) #show airmatch debug static-radios
Static Radios for Band 2GHz
Radio Base Mac    Chan EIRP Oper   /BW   /EIRP Static /BW    Flag Last Update Time    AP Name
                            Channel            Channel
ac:a3:1e:58:03:c0 Yes  Yes       11/   20/  12      11/   20      2017-02-28 12:03:57 AP1
Flag column indicates '*' if Operating Channel is different from Static Channel configured
Note: Operating Channel can be different from Static Channel during Radar event
Static Radios for Band 5GHz
                            Channel            Channel
ac:a3:1e:58:03:d0 Yes  Yes       36/   20/  23      36/   20      2017-02-28 12:04:14 AP1
Below command executed after disabling the static configuration:
(ArubaMM) [mynode] #show airmatch debug static-radios
no static radios
Version history
Revision #:
2 of 2
Last update:
‎03-26-2017 03:49 AM
Updated by:
Labels (1)
Contributors
