- Branch-config-group in primary master needs to be manually synced with backup master
- Default switchover time to secondary master incase primary master goes unreachable is 15 minutes
Topology
- Starting from AOS 6.4.4 BOC can have a backup master situated at a different geographical location
- Secondary master will allow layer 3 redundancy by being ready to take over incase primary master is not reachable
- HCM (Health check manager) will monitor secondary master as well
- Support for manual switchover to backup master is also available
Master redundancy switchover default value
(Aruba7010) #show branch master-l3redundancy switchover-timeout
switchover-timeout: 15 minutes
Support range 15-60 minutes
When primary master goes unreachable status shows red
(7010-B1) #show branch master-l3redundancy status
L3 Redundancy Status
Role IP Address Status
Master 10.16.66.6 Down
Secondary Master 10.16.66.7 Up
Health-check and uplink status
(7010-B1) #show ip health-check
IP Health-check Entries
Probe IP Src Interface State Probe-Profile Avg RTT(in ms)
10.16.66.6 -- Down default 0
10.16.66.6 vlan 200 Down default 0 >>>> Primary master reachablility status
10.16.66.6 vlan 4094 Down default 0
10.16.66.7 -- Up default 0 >>>> secondary master reachability status
192.168.2.1 -- Up default 0 >>>> default gateway
(7010-B1) #show uplink
Uplink Manager: Enabled
Uplink Health-check: Enabled
Uplink Management Table
Id Uplink Type Properties Priority State Status Reachability
1 Wired vlan 200 150 Standby Ready Unreachable
2 Wired vlan 4094 200 Connected * Active * Unreachable
VerificationTroubleshooting
#master-l3redundancy switchover
I.This is an action command to trigger forced switchover from primary to secondary master
II.Manual switchover subverts HCM and does not make any check regarding secondary master status I.e. master will switched over to backup master even if backup master is not UP
Config command:
(branch-group-<id>)# master-l3redundancy switchover-timeout <timeout>
Show commands:
For debugging any issues associated with this feature – the following logging levels should be set and logs examined
•system debugging N/A crypto
•system debugging N/A cfgm
•system debugging N/A bocmgr
•system debugging N/A fpapps
•system debugging N/A dhcpd
•system debugging N/A hcm
