How to configure Mesh using VHT?
Introduction- VHT supports mesh function from 6.4.3.0 code.  “mesh High-throughput SSID” profile is consistent with VAP ht-ssid profile so it will be kept compatible with existing APs.
Environment- From 6.4.3, the 11ac APs support mesh function:
 ap27X, ap22x, ap21x, ap20x
Network Topology- GUI
CLI
ap mesh-ht-ssid-profile <default>
         40MHz-enable
         80MHz-enable
         high-throughput-enable
         very-high-throughput-enable
         vht-txbf-explicit-enable
Answer- Backward compatibility with 11n AP
If two mesh APs are 11ac AP, the mesh link support 11AC feature
If two mesh APs are 11n AP, the mesh link support 11N feature
If one mesh AP support 11n and other mesh AP support 11ac, the mesh link support 11n feature.
Verification- Aruba7240) #show ap mesh-ht-ssid-profile default
Mesh High-throughput SSID profile "default"
Parameter                                                       Value
High throughput enable (SSID)                                   Enabled
40 MHz channel usage                                            Enabled
Very High throughput enable (SSID)                              Enabled
80 MHz channel usage (VHT)                                      Enabled
BA AMSDU Enable                                                 Enabled
Temporal Diversity Enable                                       Disabled
Legacy stations                                                 Allowed
Low-density Parity Check                                        Enabled
Maximum number of spatial streams usable for STBC reception     1
Maximum number of spatial streams usable for STBC transmission  1
MPDU Aggregation                                                Enabled
Max received A-MPDU size                                        65535 bytes
Max transmitted A-MPDU size                                     65535 bytes
Min MPDU start spacing                                          0 usec
Short guard interval in 20 MHz mode                             Enabled
Short guard interval in 40 MHz mode                             Enabled
Short guard interval in 80 MHz mode                             Enabled
Supported MCS set                                               0-23
VHT - Supported MCS map                                         9,9,9
VHT - Explicit Transmit Beamforming                             Enabled
VHT - Transmit Beamforming Sounding Interval                    25 msec
Maximum VHT MPDU size                                           11454 bytes
Maximum number of MSDUs in an A-MSDU on best-effort AC          2 MSDUs
Maximum number of MSDUs in an A-MSDU on background AC           2 MSDUs
Maximum number of MSDUs in an A-MSDU on video AC                2 MSDUs
Maximum number of MSDUs in an A-MSDU on voice AC                0 MSDUs
(Aruba7240) # show ap mesh-radio-profile default
Mesh Radio profile "default"
Parameter                                                      Value
802.11a Transmit Rates                                         6 9 12 18 24 36 48 54
802.11g Transmit Rates                                         1 2 5 6 9 11 12 18 24 36 48 54
Allowed VLANs on mesh link                                     1-4094
BC/MC Rate Optimization                                        Enabled
Heartbeat threshold                                            10
Link Threshold                                                 12
Maximum Children                                               64
Maximum Hop Count                                              8
Mesh Private Vlan                                              0
Mesh High-throughput SSID Profile                              default
Mesh Survivability                                             Disabled
Metric algorithm                                               distributed-tree-rssi
Rate Optimization for delivering EAPOL frames and mesh echoes  Disabled
Reselection mode                                               startup-subthreshold
Retry Limit                                                    8
RTS Threshold                                                  2333 bytes
(Aruba7240) # show ap mesh-recovery-profile
AP Mesh Recovery Profile
Item            Value
Cluster Name    RecoveryfoAS5q3zTQ3DSWuE
RF Band         a
Encryption      wpa2-psk-aes
WPA Hexkey      ********
WPA Passphrase  N/A
#show ap mesh topology
A new “AC” flag for 11ac product is added into the command of  “show ap mesh topology”, “show ap mesh topology long”, “show ap mesh page” and “show ap mesh start”
show ap mesh neighbors
A new “V” flag for 11ac product  is added into the command of  “show ap mesh neighbors
Troubleshooting-(Aruba7240) #show ap database
AP Database
Name        Group  AP Type  IP Address    Status        Flags  Switch IP     Standby IP
meshpoint   mesh   275      172.16.0.246  Up 3h:3m:18s  M      172.16.0.254  0.0.0.0
meshportal  mesh   275      172.16.0.251  Up 3h:6m:44s  M      172.16.0.254  0.0.0.0
(Aruba7240) #show ap mesh active
Mesh Cluster Name: aruba-mesh
Name        Group  IP Address    BSSID              Band/Ch/EIRP/MaxEIRP  MTU   Enet Ports  Mesh Role  Parent      #Children  AP Type  Uptime
meshpoint   mesh   172.16.0.246  6c:f3:7f:7d:af:10  802.11a/153E/9/23           Off/Off     Point      meshportal  0          275      3h:3m:53s
meshportal  mesh   172.16.0.251  ac:a3:1e:83:27:b0  802.11a/153E/9/23     1500  -/Off       Portal     -           1          275      3h:7m:19s
Total APs :2
(Aruba7240) #show ap mesh-cluster-profile default
Mesh Cluster profile "default"
Parameter       Value
Cluster Name    aruba-mesh
RF Band         a
Encryption      opensystem
WPA Hexkey      N/A
WPA Passphrase  N/A
(Aruba7240) #show ap active
Active AP Table
Name        Group  IP Address    11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP   AP Type  Flags  Uptime      Outer IP
meshportal  mesh   172.16.0.251  0            AP:HT:11/12/27       0            MPP+AP:VHT:153E/9/23  275      MAa    3h:12m:28s  N/A
meshpoint   mesh   172.16.0.246  0            AP:HT:6/18/27        0            MP+AP:VHT:153E/9/23   275      MAa    3h:9m:2s    N/A
Version history
Revision #:
1 of 1
Last update:
‎04-05-2015 12:21 AM
Updated by:
Labels (1)
Contributors
Tags (1)
