Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Aruba Documentation Portal
Aruba Support Knowledge Base
Community Learning
News
ACEX Hall of Fame
MVP Overview
Tech Corners
Search
View Entry
Controller Based WLANs
Community Home
Library
2.7K
Members
14
last person joined: one year ago
APs, Controllers, VIA
Back to Library
How to configure PortFast & BPDU Guard on an Aruba controller.
0
Kudos
Jul 28, 2015 12:25 PM
esupport
An Aruba controller running 6.4.3.x and above.
PortFast:
PortFast feature basically causes a switch port or a trunk port to directly enter the forwarding state instead of going through listening and learning state of the STP.
PortFast is usually configured on an edge port, which means this port should not receive any STP BPDUs.
If this port receives any STP BPDU, this port moves back to normal/regular mode and will end up participating in listening and learning states.
BPDU Guard:
The BPDU Guard feature basically guards the port against receiving any BPDUs.
If it detects any incoming BPDUs on the port, it would put the port into ErrDis (Error-Disable).
This port remains in the ErrDis state unless until this port is manually changed by using a configuration command “shut” followed by a “no-shut” applied on this interface.
Below screen shot show the configuration of Portfast for both Trunk and Access ports.
Below screen shot shows the configuration of BPDU Guard for switch ports.
We can verify if the Portfast is enabled using the commands shown in below screen shot.
We can verify if the BPDU Guard is enabled using commands shown in below screen shot.
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2024 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
