How to configure an Aruba controller for communication with RADIUS/TACACS server over IPv6?
This article explains how to configure IPv6 for Radius communication on the Aruba Controller.
Prior to AOS version 6.3.0.0, we could only configure the Aruba Controller to talk to the Radius/TACACS server using only IPv4 IP addresses. However, with AOS version 6.3.0.0, Aruba now supports communication between the controller and the Radius server using IPv6 IP address as well.
Environment : This article applies to all Aruba Controllers running OS version 6.3.0.0 or above.
Through WebUI
  1. Navigate to Configuration>Authentication> Servers> Radius Server.
  2. Choose the correct Radius server configuration and tick the “Enable IPv6” option under Radius Server configuration.
c. Navigate to Configuration> Authentication> Advanced.
     d. Configuration Global NAS and source interface address
Through CLI
Following logging levels can be enabled on the controller check Radius related logs:
(Aruba3200) #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
(Aruba3200) (config) #logging level debugging security process authmgr
(Aruba3200) (config) #logging level debugging security subcat aaa
Version history
Revision #:
1 of 1
Last update:
‎07-04-2014 04:44 PM
Updated by:
Labels (1)
Contributors
