How to configure site to site VPN for dynamically addressed peers
Introduction :
When Site to Site VPN is configured between the data center and remote branches, some controllers at the remote sites may not have static IP address on their uplink, such as the controller uplink is a PPPoE link, or behind a cable modem, or is a 3G/4G link. In this case, static peer IP address for Site to Site VPN configuration won't be feasible, dynamic peer address has to be used.
Feature Notes :
  • IKE Aggressive-Mode with authentication based on Pre-Shared-Key is used for Site to Site VPN with dynamically addressed peers.
  • IKE Main-Mode is used for Site to Site VPN with statically addressed peers.
  • IKE Main-Mode with certificates will NOT be supported for Dynamic IP peers.
Configuration Steps :
Here is a sample configuration on the data center controller and on the remote site controller:
On the data center (Hub) controller:
  1. Responder with unique map per peer
crypto-local isakmp key "******" fqdn 100
crypto ipsec transform-set default-aes esp-aes256 esp-sha-hmac
crypto-local ipsec-map dyn-sts 100
  peer-ip 0.0.0.0
  peer-fqdn fqdn-id 100
  vlan 0
  src-net 192.168.199.0 255.255.255.0
  dst-net 192.168.5.0 255.255.255.0
  set transform-set "default-transform"
  pre-connect enable
  trusted enable
  force-natt enable
        2. Responder with one map for All peers.
crypto-local isakmp key "******" fqdn-any
  peer-ip 0.0.0.0
  peer-fqdn any-fqdn
  vlan 0
  pre-connect enable
  trusted enable
  force-natt enable
On the remote site (Spoke) controller:
crypto-local isakmp key "******" address 10.163.188.10 netmask 255.255.255.255
  peer-ip 10.163.188.10
  local-fqdn 100
  vlan 0
  src-net 192.168.5.0 255.255.255.0
  dst-net 192.168.199.0 255.255.255.0
  pre-connect enable
  trusted enable
  force-natt enable
Version history
Revision #:
1 of 1
Last update:
‎07-18-2014 05:57 AM
Updated by:
Labels (1)
Contributors
