How to configure the front panel ports of an Aruba Controller to pass traffic in cpboot?
MVP
MVP
By default, when a controller with physical mgmt port (example: 7010, 7205) is in cpboot mode, it will pass traffic only through the mgmt port and not through any of the other ports.
If the laptop/switch is connected to any of the front panel ports instead of the mgmt port, we need to enable the front panel ports to have access in the cpboot mode.
To enable front panel ports:
cpboot> setenv serverip <serverIP>
cpboot> setenv ipadddr <ipaddr>
cpboot> setenv netmask <netmask>
cpboot> setenv gatewayip <gateway>
cpboot> pfe mgmt
Detecting uplink:
MarvellXphy = 0
NetlogicXphy = 1
MarvellCub  = 0
PCI3_Marvell= 0
PCI3_FPGA   = 0
Uplink=Netlogic Uplink
start bobcat(s) configuration
end bobcat configure
 QSGMII Link is down. Attempting to soft reset retry:1
 QSGMII Link is down. Attempting to soft reset retry:2
 QSGMII Link is down. Attempting to soft reset retry:3
 QSGMII Link is down. Attempting to soft reset retry:4
 QSGMII Link is down. Attempting to soft reset retry:5
 QSGMII Link is down. Attempting to soft reset retry:6
 QSGMII Link is down. Attempting to soft reset retry:7
 QSGMII Link is down. Attempting to soft reset retry:8
 QSGMII Link is down. Attempting to soft reset retry:9
 QSGMII Link is down. Attempting to soft reset retry:10
 QSGMII Link is down. Attempting to soft reset retry:11
 QSGMII Link is down. Attempting to soft reset retry:12
 QSGMII Link is down. Attempting to soft reset retry:13
 QSGMII Link is down. Attempting to soft reset retry:14
 QSGMII Link is down. Attempting to soft reset retry:15
 QSGMII Link is down. Attempting to soft reset retry:16
 QSGMII Link is down. Attempting to soft reset retry:17
 QSGMII Link is down. Attempting to soft reset retry:18
 QSGMII Link is down. Attempting to soft reset retry:19
 QSGMII Link is down. Attempting to soft reset retry:20
configured the front panel port 0 as managment port
cpboot>
cpboot> ping 10.0.0.1
Using ge-0 device
host 10.0.0.1 is alive
Version history
Revision #:
2 of 2
Last update:
‎03-20-2017 02:11 PM
Updated by:
Labels (1)
Contributors
