How to connect to an Aruba controller using ssh with certificates from a linux machine
From the WebUI Configuration page:
1.   Upload a client certificate to the controller:
             Management -> Certificates -> Upload
2.   Enable SSH authentication using Client public key:
                Management -> General
3.   Add a management user:
Management -> Administration -> Add User
On a linux machine:
  1. Copy the client certificate private key to the user's directory ~/.ssh/ folder
  2. Change its owner to the user and its access permissions to 600.
  3. Optionally rename it to id_rsa
  4. if not renamed, run the following command:  "ssh -i ~/.ssh//<private key> <username>@<controller IP address>"
  5. You may get prompted for the private key passcode if set, and once entered you will get the controller prompt.
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 03:35 PM
Updated by:
Labels (1)
Contributors
