How to create LLDP profile for AP on Aruba Controllers running AOS 8.x?
MVP
MVP
Aruba controllers or VMware should be running minimum 8.x
LLDP is a Layer-2 protocol that allows network devices to advertise their identity and capabilities on a LAN. Wired interfaces on Aruba APs support LLDP by periodically transmitting LLDP PDUs.
From WebUI:
From CLI:
Syntax:
(host) [md] (config) #ap lldp profile <profile>
(host) ^[md] (AP LLDP Profile "<profile>") #receive
(host) ^[md] (AP LLDP Profile "<profile>") #transmit
Example:
(Aruba) [md] (config) #ap lldp profile Test-Aruba-LLDP
(Aruba) ^[md] (AP LLDP Profile "Test-Aruba-LLDP") #receive
(Aruba) ^[md] (AP LLDP Profile "Test-Aruba-LLDP") #transmit
NOTE: This feature can be configured only on Managed Devices (MD), Mobility Master(MM) does not support this configuration.
(Aruba-MM) *[md] #show ap lldp profile Test-Aruba-LLDP
Parameter                        Value
PDU transmission                 Enabled
Reception of LLDP PDUs           Enabled
(Aruba-MM) *[md] #
Version history
Revision #:
1 of 1
Last update:
‎02-28-2018 01:13 AM
Updated by:
