How to define setenv variables from apboot for secondary master on Remote Access Point.
Q:
A:
Secondary Master can also be configured from AP boot using setenv variables. After gaining  console access to the access point, interrupt the apboot and configure the values as shown below.
Note : Console access is required to define this setenv parameter.
Hit <Enter> to stop autoboot:  0   ---> Interrupt the boot sequence by hitting any key
apboot>
apboot>
apboot>setenv secondary_master <ip/fqdn>
Version history
Revision #:
2 of 2
Last update:
‎03-30-2017 12:09 AM
Updated by:
Labels (1)
Contributors
