How to determine if an AP is configured to do dot1x authentication before being able to pass any IP traffic?
Question: How to determine if an Aruba AP is configured to do dot1x authentication before being able to pass any IP traffic?
Environment:This article applies to AOS version 6.3 or higher
Any AP that shows up in the “show ap active” table with the flag “1” is doing 802.1x authentication as shown in the output below:
(host) # show ap active
Active AP Table
Name Group IP Address 11g Clients 11g Ch/EIRP/MaxEIRP 11a Clients 11a
Ch/EIRP/MaxEIRP AP Type Flags Uptime Outer IP
Test-AP default 10.3.15.107 0 AP:HT:1/15/21.5 0 AP:HT:44/15/21
125 1E2 5m:48s N/A
Flags: a = Reduce ARP packets in the air; A = Enet1 in active/standby mode;
B = Battery Boost On; C = Cellular; D = Disconn. Extra Calls On;
d = Drop Mcast/Bcast On; E = Wired AP enabled; K = 802.11K Enabled;
L = Client Balancing Enabled; M = Mesh; N = 802.11b protection disabled;
P = PPPOE; R = Remote AP; X = Maintenance Mode;
1 = 802.1x authenticated AP; 2 = Using IKE version 2;
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 04:55 PM
Labels (2)
Contributors
