Q:
How to disable AMSDU completely on controller?
To disable AMSDU completely, it has to be disabled at the firewall and WLAN-HT-SSID profile.
In WLAN-HT-SSID profile, block-ack AMSDU should be disabled and Max-Tx-AMSDU count for all traffic should be set to 0. If there are multiple WLAN-HT-SSID profiles in use, the changes should be made to all WLAN-HT-SSID profiles.
Example: ========
(Rajaguru-3200XM) #configure terminal Enter Configuration commands, one per line. End with CNTL/Z (Rajaguru-3200XM) (config) #no firewall amsdu (Rajaguru-3200XM) (config) #wlan ht-ssid-profile default no ba-amsdu-enable (Rajaguru-3200XM) (config) #wlan ht-ssid-profile default max-tx-a-msdu-count-be 0 (Rajaguru-3200XM) (config) #wlan ht-ssid-profile default max-tx-a-msdu-count-bk 0 (Rajaguru-3200XM) (config) #wlan ht-ssid-profile default max-tx-a-msdu-count-vo 0 (Rajaguru-3200XM) (config) #wlan ht-ssid-profile default max-tx-a-msdu-count-vi 0 (Rajaguru-3200XM) (config) #exit (Rajaguru-3200XM) #write memory Saving Configuration... Configuration Saved. (Rajaguru-3200XM) #
