How to do a seamless login to a Mobility Device (MD) from Mobility Master (MM)?
MVP
MVP
Q:
A:
We can login to any mobility device (MD) from Mobility Master using the command "mdconnect". In order to do the same, we need to change the directory to that particular MD and execute "mdconnect". Below are the sample steps:
(ArubaMM) ^[mynode] #cd /md/Cluster_2/00:0b:86:b5:4d:c7
(ArubaMM) ^[00:0b:86:b5:4d:c7] #mdconnect
<cr>
Redirecting to Managed Device Shell
Last login: Tue Mar 14 07:24:36 2017 from 10.20.35.143
(Aruba-MD2) [MDC] #
On no activity, the session will be logged out similar to any other SSH session and will log you back in MM:
(Aruba-MD2) [MDC] #
*** IDLE TIMEOUT ***
Connection closed by foreign host.
Exiting Managed Device Shell
Version history
Revision #:
2 of 2
Last update:
‎03-17-2017 02:40 PM
Updated by:
Labels (1)
Contributors
