How to do band steering for a client on the controller manually?
MVP
MVP
This Command is applicable only from AOS: 6.3.x onwards.
This command will work only in enable mode on the controller.
We have introduced a client specific command from AOS: 6.3.x so that we could do band steering for a specific client instead of applying it to a profile that affects all the clients falling under the profile.
Syntax:
(Aruba) #arm move-sta <client-mac> <bss-id of 5Ghz> reason bandsteer
To find the BSSID please use the following command
(Aruba) #show ap bss-table ap-name <name of the ap to which the client is connected>
Example:
(Aruba) #arm move-sta 00:18:9d:87:hf:bf 00:0b:86:95:98:19 reason bandsteer
To view the client band we could use the following command
(Aruba) #show ap association client-mac <cliient-mac>
Version history
Revision #:
2 of 2
Last update:
‎11-25-2015 04:20 PM
Updated by:
Labels (1)
Contributors
Comments
tejen_bhandari
how can i do from GUI?
this only can done from command line ? if it can be done so where i can do ?
thanks
Unfortunately,  this is not possible from GUI.
Rajaguru Vincent
tejen_bhandari
i have tried band steering however it just dont happen
can you plz give me exact "syntax"
i have 72005 controller
with 150 AP
(ARUBA-MASTER) #show version
ArubaOS (MODEL: Aruba7205), Version 6.4.3.1
Website: http://www.arubanetworks.com
Copyright (c) 2002-2015, Aruba Networks, Inc.
Compiled on 2015-04-21 at 17:17:53 PDT (build 49733) by p4build
ROM: System Bootstrap, Version CPBoot 1.0.1.0 (build 48228)
Built: 2015-01-22 04:53:25
Built by: p4build@re_client_48228
Switch uptime is 6 days 22 hours 23 minutes 33 seconds
Reboot Cause: User reboot (Intent:cause:register 78:86:0:2c)
Supervisor Card
Processor (XLP316 Rev B2 (Secure Boot) , 1200 MHz) with 7882M bytes of memory.
32K bytes of non-volatile configuration memory.
3872M bytes of Supervisor Card system flash.
