How to enable automatically send email to guest and sponsor when the guest user is created?
Need to trigger emails automatically to guest and sponsor, when the guest user account is created in the local-user database.
This can be done by enabling the below option from the controller either from the CLI or from the WEBUI.
Make sure we have the SMTP server configured on the controller for the emails to work.
SMTP configuration can be verified from the below command:
(Aruba) (config) #show guest-access-email
Guest-access Email Profile
Parameter    Value
SMTP Server
SMTP Port    25
Before enabling the option:
(Aruba) (config) #show running-config | include local-
Building Configuration...
Commands to enable the automatic email trigger:
(Aruba) (config) #
(Aruba) (config) #local-userdb send-to-?
send-to-guest           Automatically send email to guest when guest user is created
send-to-sponsor      Automatically send email to guest sponsor when guest user is created
(Aruba) (config) #local-userdb send-to-guest
(Aruba) (config) #local-userdb send-to-sponsor
After enabling the option:
We can enable this option from the WEBUI as well from the below screen:
Configuration>MANAGEMENT>Guest Provisioning> From the "Email" tab:
Check the option "Send automatically at account creation time" under both Guest Message and Sponsor Message.
Emails sent and dropped can be verified from the below counters:
(Aruba) (config) #show util_proc guest-email counters
Guest Email Counters
Name            Value
Email Received  0
Email Sent          2
Email Dropped  0
Version history
Revision #:
2 of 2
Last update:
‎10-18-2016 02:59 PM
Updated by:
Labels (1)
