How to enable debugging on Aruba OS 8.x?
MVP
MVP
This will help us to enable debugging for a user/AP and for any of the process on the controller.
We enable debugging mainly for troubleshooting, this will give a syntax on how the user/AP and process debug can be done on 8.x.
From 8.x the debugging command syntax has been modified as below:
For user-debugging:
(Aruba) ^[mynode] (config) #logging user-debug <aa:bb:cc:dd:ee:ff> level debugging
For AP-debugging:
(Aruba) ^[mynode] (config) #logging ap-debug <ap-name> level debugging
For process debugging:
(Aruba) ^[mynode] (config) #logging security level debugging
(Aruba) ^[mynode] (config) #logging network process dhcpd subcat dhcp level debugging
We can verify the debugging only if we give write memory:
AP/User debugging can be verified by the below command:
(Aruba) [mynode] (config) #show debug
DEBUG LEVELS
Facility    Level      Debug Value        Sub Category  Process
ap-debug    debugging  Test               N/A           N/A
user-debug  debugging  aa:bb:cc:dd:ee:ff  N/A           N/A
Process debugging can be verified by the below command:
(Aruba) [mynode] (config) #show logging level verbose | include debugging
network   debugging  dhcp          dhcpd
security  debugging  N/A           N/A
Version history
Revision #:
2 of 2
Last update:
‎03-29-2017 10:39 AM
Updated by:
Labels (1)
Contributors
Comments
erikham
