How to enable usb port on the AP
MVP
MVP
Q:
what does the ap-usb-power-override command actually does in 6.4.3 (AP System Profile)?
A:
This will enable the USB port on AP platforms where the default behavior is to disable it when the AP is powered by 802.3af POE.
Version history
Revision #:
2 of 2
Last update:
‎07-16-2015 03:47 AM
Updated by:
Labels (1)
Contributors
