How to formats the flash file system in the controller using CLI
MVP
MVP
Q:
How to format the flash file system in the controller using CLI
A:
Starting from ArubaOS 6.4.4.0, the wipe out flash command is introduced. This command erases all data including configuration, logs, license keys, flash backup files and formats the flash file system in the controller.
(Aruba3600) #wipe out flash
Entire flash will be formatted.
Images on both the partitions, configuration and databases will be deleted. Press 'y' to proceed :
Note: Execute this command only when the controller is taken out of service or decommissioned.
Tested in 6.4.4.0 image version.
Version history
Revision #:
2 of 2
Last update:
‎03-07-2016 11:54 AM
Updated by:
Labels (1)
Contributors
