How to merge two stacks, configured with pre-set
While merging two stacks Stack A and Stack B and you want Stack A to take over the entire stack, it is always recommened to reset the other stack configuration.  On Stack B execute  "restore factory_default stacking"  and then add the Serial number of these member to Stack A.
In a two-member stack with split-detection enabled, both the members of the stack remain active.
(WINNER STACK) #show stacking members
Member status: Active, Stack Id: 000b866a5ac04f7a47c4 Stack uptime: 19 minutes 57 seconds
Id Role MAC Address Priority State Model Serial
0 * Primary 000b.866a.5ac0 Preset Active ArubaS3500-48P AW0000155
2 Secondary 000b.866a.7500 Preset Active ArubaS3500-24T AU0000229
Disable split-detection
(WINNER STACK) #show stack-profile stack-profile "default"
Parameter Value
MAC persistence timeout 15 Minutes Split Detection Disabled
Preset-profile:
Member-id Serial-number Role
0               AW0000155      Primary-capable
2               AU0000229      Primary-capable
In the case the stack is down or the stack interfaces go down, both units will act as independent Primary
Stack uptime: 22 minutes 13 seconds
2 Unknown 000b.866a.7500 Preset Away ArubaS3500-24T AU0000229
Output  as shown on the member 2 console.
Member status: Active, Stack Id: 000b866a75004f7a4e44
Stack uptime: 22 minutes 29 seconds
0 Unknown 000b.866a.5ac0 Preset Away ArubaS3500-48P AW0000155
2 * Primary 000b.866a.7500 Preset Active ArubaS3500-24T AU0000229
Once the stack interface are back up the stack is re-formed as original stack
Stack uptime: 26 minutes 6 seconds
Version history
Revision #:
1 of 1
Last update:
‎07-08-2014 01:55 PM
Updated by:
Contributors
