How to set Administrator Session Timeout for the WebUI and CLI of the controller ?
Environment: This article applies to All Aruba Mobility Controllers running ArubaOS.
Sometimes we come across situation where the WebUI and CLI session to controller gets timed out , to overcome that we can configure the number of seconds after which an Administrator’s WebUI or CLI session times out.
For the WebUI
To define a timeout interval for a WebUI session, use the command:
web-server sessiontimeout <session-timeout>
In the above command, <session-timeout> can be any number of seconds from 30 to 3600, inclusive.
For the CLI
To define a timeout interval for a CLI session, use the command:
loginsession timeout <value>
In the above command, <val> can be any number of minutes from 5 to 60 or seconds from 1 to 3600, inclusive. You
can also specify a timeout value of 0 to disable CLI session timeouts.
Version history
Revision #:
2 of 2
Last update:
‎06-26-2014 04:44 PM
Updated by:
Labels (1)
Tags (1)
For version, the Web UI syntax is:
(controller) (config) #web-server profile
(controller) (Web Server Configuration) #   session-timeout ?
<session-timeout>       Configure user's WebUI session timeout <30-3600>
web-server profile
   session-timeout 1800
CLI syntax is the same as above.
Anyone know if the CLI Session timeout has been deprecated and hopefully replaced with a new commands. does not support the CLI commands listed.
I see these were for ArubaOS.
Anyone know commands for Instant CLI session timeout? I dont see anything in the CLI guide.
Is there a way to change the GUI timeout on an Instant Access point?
Not that I can find.
