Starting from 8.x we can bring up the 72xx, 70xx controllers as MD on a MM using Zero Touch Provision.
1. Once the device is added to Activate, set the mode of MD to "Managed Device.":
2. Configure the rule "Managed Device to Master Controller" and provide the details about the MM.
3. Configure the Activate credentials on MM.
#activate #whitelist-enable #username "activate_username" #password "password"
Once the MD has got IP address/DNS from DHCP server, it automatically contacts Activate and receives the MM information from Activate.
From the console logs of MD:
Received DHCP response, My IP = 10.17.168.30, Master = none, Country code = none Master info not received from DHCP, trying activate Received Activate response, My Role = md, Master = 10.17.164.171, Master MAC = 00:50:56:9F:E7:A1, Hostname = ZTP-MD, Country code = US, Redundant Master MAC = none VPN IP = none, VPN MAC = none, Redundant VPN MAC = none Master = 10.17.164.171 auto-discovered from Activate
(Abdul-MM) [mynode] #show running-config | include local-custom Building Configuration... local-custom-cert local-mac "00:0b:86:dd:4f:20" ca-cert factory-ca-cert server-cert self-signed-field-cert --> whitelist entry pushed from Activate.
Note: Controller syncs regularly to get the whitelist details from Activate. If not, execute the command #activate sync
Total Switches:2
(Abdul-MM) [mynode] #show activate
activate -------- Parameter Value --------- ----- Activate Whitelist Service Enabled Activate URL https://activate.arubanetworks.com/ Provision Activate URL https://device.arubanetworks.com/ Activate Login Username rvincent Activate Login Password ******** Periodic Interval for WhiteList Download 1 Add-Only Operation Enabled Custom cert to upload to Activate N/A Server cert to be used for IPSEC N/A (Abdul-MM) [mynode] #
