How to tunnel all traffic in split tunnel mode while conncted through VIA
Environment- Tested in version.
Answer- Enable split tunnel and add following route to achieve it.
Command to Enable Split tunnel
aaa authentication via connection-profile "via conneection profile"
 Command to Add the route
(via-blr1) (config) #aaa authentication via connection-profile <via connection
(via-blr1) (VIA Connection Profile "default") #tunnel address netmask
Note: is not allowed to add through web UI, hence please add the  route through SSH on
Version history
Revision #:
1 of 1
Last update:
‎04-05-2015 12:26 AM
Updated by:
Labels (1)
Out of interest: what's the advantage of this over not using split tunnel?
