Q: How to upgrade 7000 series controllers through USB ?
A: Controller will look for a particular folder (Arubaimage) in USB for code upgrade. Hence create a folder called "Arubaimage" in USB and copy AOS image into that folder
After we insert the USB to the controller we can use the below commands to verify the connection
(Aruba7005) #show usb
USB Device Table
Address Product Vendor ProdID Serial Type Profile State
3 v220w 03f0 5a07 0425370000006838 Storage
2 USB DISK 090c 1000 AA00000000009226 Storage
(Aruba7005) # show storage
Filesystem Size Used Available Use% Mounted on
none 2.0G 2.7M 2.0G 0% /tmp
/dev/usbdisk/slot0/1 7.5G 196.6M 7.3G 3% /mnt/usbdisk/slot0/1
/dev/usb/flash3 1.4G 104.2M 1.3G 7% /flash
(Aruba7005) #show usb verbose
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=03f0 ProdID=5a07 Rev=11.00
S: Manufacturer=HP
S: Product=v220w
S: SerialNumber=0425370000006838
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=300mA
We can use the below command to upgrade the image .Please note that we need to mention the USB slot/partition which can be verified using "show storage" command
(Aruba7005) #copy usb: partition ?
<part> Enter the slot:partition number of external USB for
copy,default slot 0
(Aruba7005) #copy usb: partition 1 ArubaOS_70xx_6.4.2.10_50952 system: partition 0
Upgrading partition 0
File ArubaOS_70xx_6.4.2.10_50952 copied to partition 0 successfully.
The system will boot from partition 0 during the next reboot.
(Aruba7005) #show image version
Partition : 0:0 (/dev/usb/flash1) **Default boot**
Software Version : ArubaOS 6.4.2.10 (Digitally Signed - Production Build)
Build number : 50952
Label : 50952
Built on : Wed Jul 22 13:21:13 PDT 2015
Partition : 0:1 (/dev/usb/flash2)
Software Version : ArubaOS 6.4.2.3 (Digitally Signed - Production Build)
Build number : 47524
Label : 47524
Built on : Sat Dec 6 11:24:05 PST 2014
Please note if we notice the error "file not found" when executing the upgrade command then reboot the controller and try again
