How to verify if an AP is transmitting beacons
For a dual band AP run the following commands multiple times to verify that the “Beacons Transmitted” counter is incrementing:
Band a:
(mm6000-M3) #show ap debug radio-stats ap-name M3-ap125 radio 0 advanced | include Beacon
Resets Beacon Fail        0
Beacons Transmitted       162148
Failed Beacons            26
Multi-Beacon Fail         0
Beacon Interrupts         81126
Beacons Received          0
Beacons Transmitted       162236
Failed Beacons            26
Multi-Beacon Fail         0
Beacon Interrupts         81170
Beacons Received          0
Beacons Transmitted       162298
Failed Beacons            26
Multi-Beacon Fail         0
Beacon Interrupts         81201
Beacons Received          0
Band g:
(mm6000-M3) #show ap debug radio-stats ap-name M3-ap125 radio 1 advanced | include Beacon
Beacons Transmitted       171736
Failed Beacons            1281
Multi-Beacon Fail         0
Beacon Interrupts         87163
Beacons Received          0
Beacons Transmitted       171798
Failed Beacons            1281
Multi-Beacon Fail         0
Beacon Interrupts         87194
Beacons Received          0
Beacons Transmitted       171828
Failed Beacons            1281
Multi-Beacon Fail         0
Beacon Interrupts         87209
Beacons Received          0
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 02:27 PM
Updated by:
Labels (1)
Contributors
