How to wipe the AP`s flash completely from controller?
MVP
MVP
Q:
A:
Yes. Here is the command to wipe the AP flash from controller. You can erase the config either with specific ap-name or ip address of the AP.
ap wipe out flash
ap-name <ap-name>
ip-addr <ip-addr>
This command will overwrite the entire AP compact flash, destroying its contents (including the current image file).
Note: Validated on Aruba OS 6.2
Version history
Revision #:
2 of 2
Last update:
‎06-02-2015 02:56 AM
Updated by:
Labels (1)
Contributors
Comments
mihulko
Does not appear to be supported in 6.4.3.3  Cannot find command on either Master or Local controllers
