I have upgraded my 651 controller from Aruba OS 6.1.x.x to 6.2.x.x and the internal AP is not showing any more ?
Environment  :  This article applies to Aruba-651 controller model while upgrading from Aruba OS 6.1.x.x to 6.2.x.x or 6.3.x.x version
Upon upgrade to Aruba OS 6.2..x.x or 6.3.x.x , the internal AP of the 651 controller will be disabled automatically. The controller will continue operate as a 650 controller.
Prior to 6.2.x.x version, this internal ap was causing trouble on the controller’s performance, since this has been removed from the controller.
Version history
Revision #:
1 of 1
Last update:
‎07-03-2014 02:31 PM
Updated by:
Labels (1)
Tags (2)
