In which use case, do we notice HA-FV (Home agent/Foreign VLAN ) concept in IP mobility
Environment Information : This article applies to Aruba Mobility Controllers with IP Mobility enabled.
Symptoms : In use cases , where user move from an AP to another and thereby do not retain the IP address. This article helps us to identify the Home and Foreign VLAN for an user and see if the IP mobility is functioning as expected.
Resolution :
Consider two AP's on the same controller provisioned  in different AP groups . Both the groups have same SSID profile but the VLAN mapped is different . When the user roams from the first AP (AP-Group:V2 )to the second AP (AP-Group: V1) then controller marks the roaming status of the users as in Home switch/Foreign VLAN and the user retains the same IP address
User-added image
1: When the user is connected to first AP, the user falls in VALN 2 (20.1.1.0)
#show user
Users
  IP           MAC            Name     Role           Age(d:h:m)  Auth  VPN link  AP name            Roaming   Essid/Bssid/Phy                     Profile   Forward mode  Type     Host Name
20.1.1.2    8c:77:16:5f:da:9e            authenticated  00:00:00                    9c:1c:12:c2:83:9c  Wireless  dot1x-logon/9c:1c:12:a8:39:c0/g-HT  dot1xaaa  tunnel        Android
#show ip mobile trail 8c:77:16:5f:da:9e
Station location trail list, 3 location(s)
9c:1c:12:c2:83:9c on switch 172.16.0.254 Station 8c:77:16:5f:da:9e
   Roaming Status: Home Switch/Home VLAN, started Sat Apr 26 02:02:24 2014
   Local VLAN 2, dot1x-logon/9c:1c:12:a8:39:c0/g
#show ip mobile host
Mobile Host List, 1 host(s)
8c:77:16:5f:da:9e
   IPv4: 20.1.1.2
   Roaming Status: Home Switch/Home VLAN, Service time 0 days 00:00:43
   Home VLAN 2
2: When the user roams to the second AP the controller marks that user as in foreign VLAN and the ip address is retained.
#show user-table
Users
20.1.1.2    8c:77:16:5f:da:9e            authenticated  00:00:01                    9c:1c:12:c3:ab:f8  Foreign VLAN  dot1x-logon/9c:1c:12:ba:bf:81/g-HT  dot1xaaa  tunnel        Android
#show ip mobile trace 8c:77:16:5f:da:9e
Mobility Trace Host details
Station: 8c:77:16:5f:da:9e IPv4: 20.1.1.2  HA: 0.0.0.0  FA:0.0.0.0
Host Roaming Status: Home Switch/Foreign VLAN
8c:77:16:5f:da:9e
   IPv4: 20.1.1.2
   Roaming Status: Home Switch/Foreign VLAN, Service time 0 days 00:01:40
   Home VLAN 2, visiting local VLAN 1
# show datapath bridge table
Datapath Bridge Table Entries
Flags: P - Permanent, D - Deny, R - Roamed Client, M - Mobile, X - Xsec, A - Auth, O - Outer VLAN, T - Trusted
      MAC          VLAN  Assigned VLAN  QinQ VLAN  Destination  Flags    Age
8C:77:16:5F:DA:9E  2     2              0          tunnel 12    PMR      0  ---->SRC lookup,Assigned VLAN takes precedence
8C:77:16:5F:DA:9E  1                 0          tunnel 12    PM       0
      ---->DST lookup
Version history
Revision #:
1 of 1
Last update:
‎07-14-2014 11:56 PM
Updated by:
Labels (1)
Contributors
