Is Apprf and WebCC part of global configuration or specific to local?
MVP
MVP
Q:
Is Apprf and WebCC are part of global configuration or specific to local?
A:
In a Master-Local Setup, even though the user role configuration that includes DPI and WebCC/Apprf gets replicated across the Locals, for the AppRF or the WebCC to work on all the Local Controllers, DPI should be enabled on each local Controllers under stateful firewall. Hence for the same reason, AppRF and Web CC are not global configuration as they depend on DPI feature in the firewall.
Note: Also Web CC under firewall has to be enabled as well for the Web Category to work on all Local controllers.
Output from Master
(MasterController-7005) (config) #show switches
All Switches
IP Address     Name                   Location          Type    Model      Version        Status  Configuration State  Config Sync Time (sec)  Config ID
10.17.171.195  MasterController-7005  Building1.floor1  master  Aruba7005  6.4.4.9_55980  up      UPDATE SUCCESSFUL    0                       7
10.17.171.196  Local-Controller7005   Building1.floor1  local   Aruba7005  6.4.4.9_55980  up      UPDATE SUCCESSFUL    2                       7
Total Switches:2
(MasterController-7005) #show firewall
Global firewall policies
Policy                                       Action                                            Rate       Port
DPI Classification                           Disabled [Cfg: disabled, PEF license: installed]
Web Content Classification                   Disabled
(MasterController-7005) (config) #firewall dpi
(MasterController-7005) (config) #firewall web-cc
(MasterController-7005) (config) # write memory
Saving Configuration...
Configuration Saved.
All Switches
10.17.171.195  MasterController-7005  Building1.floor1  master  Aruba7005  6.4.4.9_55980  up      UPDATE SUCCESSFUL    0                       8
10.17.171.196  Local-Controller7005   Building1.floor1  local   Aruba7005  6.4.4.9_55980  up      UPDATE IN PROGRESS   0                       7
Total Switches:2
All Switches
10.17.171.196  Local-Controller7005   Building1.floor1  local   Aruba7005  6.4.4.9_55980  up      UPDATE SUCCESSFUL    2                       8
Output from Local
(Local-Controller7005) # show switches
All Switches
10.17.171.196  Local-Controller7005  Building1.floor1  local  Aruba7005  6.4.4.9_55980  up      UPDATE SUCCESSFUL    0                       8
Total Switches:1
(Local-Controller7005) #show firewall
Version history
Revision #:
2 of 2
Last update:
‎04-23-2017 12:18 AM
Updated by:
Labels (1)
Contributors
