Is it possible to bind clients to a specific AP nearby and prevent the controller from sending De-auth?
Environment- This article is applicable to controllers running 6.3.x
Answer- Requirement:-
For instance we have some users with Android devices running specific application (connects to a cloud server) that does not support roaming. If the client roams between APs then connection is dropped. Its possible these clients are within a specific area.
Answer:-
There is no configuration that would allow the controller to only allow a client to connect to a specific SSID. There are utilities/apps out there that can be installed on the client that can lock it to a certain BSSID.
If you want the controller to NOT make any client moves using clientmatch, you can add the client to the clientmatch unsupported list.
Workaround:
Disable ARM on the controller so it doesn't de-auth clients.
Install an app on the device to bind to specific AP.
Since its more of poor design it needs to be addressed with App developers
Related Links- https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/HOW-TO-DISABLE-CLIENT-MATCH-FOR-A-SPECIFIC-CLIENT
Version history
Revision #:
1 of 1
Last update:
‎04-05-2015 11:20 PM
Updated by:
Labels (2)
Contributors
