Is it possible to enable Radius Accounting for open ssid?
MVP
MVP
Q:
How to enable Radius Accounting for Open SSID?
A:
Starting from Aruba OS 6.4.3.0, Radius Accounting can be enabled for open ssid.
Configuration from Web UI:
Navigate to Configuration ->All Profile ->Select Wireless LAN
Select Specified aaa profile under AAA section
Enable “Open SSID accounting” knob in aaa profile
Configuration from CLI:
Enable Open SSID Accounting:
# aaa profile pAAA
#open-system-radius-accounting
#show aaa profile pAAA
RADIUS Accounting Server Group      svrGrp
Open SSID radius accounting         Enabled
To Disable Open SSID Accounting:
# aaa profile pAAA
#no open-system-radius-accounting
Version history
Revision #:
2 of 2
Last update:
‎02-08-2016 10:34 AM
Updated by:
Labels (1)
Contributors
