Is it possible to prevent an internal AP in an Aruba 651 Controller from using a license?
Product and Software: This article applies to Aruba 651 Controller and all ArubaOS versions.
No, the Aruba 651 controller is designed to operate with the internal AP thereby using a license at all times.
Even if we disable the internal AP, the 651 controller still uses a license.
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 06:33 PM
Updated by:
Labels (1)
Contributors
Tags (1)
