Environment Master - Local setup
Turning off IP mobility globally should be sufficient by executing “no router mobile” on master and local controllers. Its not required to disable mobileip in VAP profile if the IP mobility is disabled globally. It’s recommended to reload all controllers after issuing “no router mobile” to disable IP mobility.
Turning off IP mobility globally should be sufficient by executing “no router mobile” on master and local controllers. It’s recommended to reload all controllers after issuing “no router mobile” to disable IP mobility.
