This article explains a new feature introduced in AOS version 6.2 to trigger an alert when following parameters cross the configured threshold on the controller:
This article applies to all the controllers running a minimum of AOS version 6.2. OS versions prior to 6.2 do not support this feature.
Environment : All the sample outputs in this article have been tested on AOS version 6.2.0.2 running on a 3200XM controller.
This article has been created using a standalone 3200XM controller running 6.2.0.2.
The default threshold values are shown below:
This article explains the configuration of the “user capacity” parameter. Rest all parameters can be configured the same way.From CLI:Here we are changing the user-capacity threshold from the default of 80% to 50%.
To revert the configuration back to the default value:
From WebUI:
