Is there a recommended procedure to connect the connectors between an AP-224 and AP-ANT-35A antenna?
Q:
A:
AP-220 series has 3 Antenna connectors (ANT0, ANT1, ANT2).
In the AP-ANT-35A antenna there are 3 connectors but there is no notification on those slots similar to the ones on the APs.
Answer:
There is no recommended order. Any arrangement will  work fine.
Version history
Revision #:
2 of 2
Last update:
‎07-16-2015 07:11 AM
Updated by:
Labels (1)
Contributors
