Is there way to determine what switch and port an access point is connected?
Environment- This article is applicable to network with Airwave
Answer- In order to locate the AP in case there is any confusion with the labels . We can use AirWave which is used to monitor all wireless and wired devices.
If you have Airwave in the network we can view the monitoring screen on the AP. It would list the upstream device and port.
Version history
Revision #:
1 of 1
Last update:
‎04-05-2015 11:28 PM
Updated by:
Labels (1)
Contributors
