Master discovery mechanism work in IPv6
MVP
MVP
Q:
How does master discovery work in IPv6?
A:
For IPv6:   Currently, Master can only be provisioned manually (static configuration) and the auto discovering is not supported.
For IPv4:   Master discovery hierarchy is depends on provisioned manually (static configuration) > DHCP options (43 /60) > ADP (broadcast / multicast) > DNS (aruba-master)
Version history
Revision #:
2 of 2
Last update:
‎10-18-2016 03:01 PM
Updated by:
Labels (1)
Contributors
