Mobility Master CLI prompt shows a '^' sign constantly. What does it mean and how to get rid of it?
MVP
MVP
Q:
Mobility Master CLI prompt shows an '^' sign constantly . What does it mean and how to get rid of it ?
A:
The '^' at the CLI prompt means there is configuration that is not committed yet. This 'uncommitted' or 'pending' config could be under any config node path.
The command "show configuration unsaved-nodes" will show the node path that has unsaved config.
(MM) ^[mynode] #show configuration unsaved-nodes
List of unsaved configuration nodes
Nodename
/md/Bangalore/00:0B:86:B5:CD:A7
/md/Chennai/00:0B:86:B5:F3:77
Go to that node and do a 'write mem'. The '^' should now go away.
(MM) ^[mynode] #cd /md/Bangalore/00:0B:86:B5:CD:A7
(MM) ^[00:0b:86:b5:cd:a7] #write memory
Version history
Revision #:
2 of 2
Last update:
‎03-28-2017 01:52 AM
Updated by:
Labels (1)
Contributors
