Mobility Master Redundancy in ArubaOS 8
Community Manager
Community Manager
 Aruba Tech Notes are brief best practice recommendation documents specifically designed to outline how a particular aspect of Aruba technology works as well as to advise customers how deploy it with their Aruba solution to achieve optimal results. This document describes the concept of Mobility Master redundancy in ArubaOS 8. In addition, this document will outline best practices around creating a proper hierarchical configuration to achieve optimal results.
Version history
Revision #:
3 of 3
Last update:
‎05-04-2018 11:14 AM
Updated by:
Labels (1)
Contributors
Comments
Chris F
There doesn't appear to be anything here. Is there supposed to be a link?
Samuel089
Is there a download link
There's no document attached here.
