My APs are crashing continuously. What driver log level should I set in AP system profile?
MVP
MVP
Q:
1. APs are constantly crashing. Should I increase driver log level for more verbose data collection?
2. Why should I set the driver log level to warning in AP system profile?
A:
In the codes 6.4.4.x we can set the AP driver log level. Default is "emergencies".
(master) (config) #ap system-profile test
(master) (AP system profile "test") #exit
(master) (config) #show ap system-profile test
Parameter                               Value
RF Band                                 g
RF Band for AM mode scanning            all
Native VLAN ID                          1
Tunnel Heartbeat Interval               1
Session ACL                             ap-uplink-acl
Corporate DNS Domain                    N/A
SNMP sysContact                         N/A
LED operating mode (11n/11ac APs only)  normal
LED override                            Disabled
Driver log level                        emergencies
SAP MTU                                 N/A
RAP MTU                                 1200 bytes
LMS IP                                  N/A
Backup LMS IP                           N/A
LMS IPv6                                N/A
To get more verbose output, we can set it to "warnings".
(master) (AP system profile "test") #driver-log-level warnings
(master) (config) #
Parameter                               Value
RF Band                                 g
Native VLAN ID                          1
SNMP sysContact                         N/A
Driver log level                        warnings
SAP MTU                                 N/A
RAP MTU                                 1200 bytes
Now the AP crash information will include more verbose driver logs for debugging. Once this is configured, provide the AP tech support to Aruba TAC for analysis for any AP crash.
Version history
Revision #:
2 of 2
Last update:
‎05-18-2016 01:37 PM
Updated by:
Labels (1)
Contributors
