No plan Tab on the controller running AOS 6.3 and above
Environment : This article applies to Aruba Mobility Controllers running ArubaOS version and above
The RF Plan functionality will no longer be in the controller starting from AOS 6.3, Rather customers can use VisualRF Plan or VisualRF module on AMP sever.
The VisualRF Plan is a standalone Windows client that can be used for planning sites that do not yet use the Aruba Airwave. You can use VisualRF Plan to do basic planning procedures like adding a floor plan, provisioning APs, and generating a Bill of Materials (BOM) report. VisualRF Plan is free to use for anyone with an Aruba support account. No license is required. The client can be downloaded from the Aruba Support Center. On, select the Download Software link, which will display a tree view of Aruba software. Select the AirWave directory, and then the VisualRF Plan sub directory. The figure below shows the page that displays.
For more advanced features the VisualRF module on the Airwave provides a real-time picture of the actual radio environment of your wireless network and the ability to plan the wireless coverage of new sites.
Version history
Revision #:
1 of 1
Last update:
‎06-29-2014 03:35 PM
Updated by:
Labels (1)
