Not able to delete the IPM configuration from the web interface
MVP
MVP
Q:
Why its not possible to delete the IPM configuration from the web interface ?
A:
When IPM is enabled, at least one steps should be added by the user. If no steps are added then  “default steps” will be added automatically.
If IPM is enabled and then if we try to delete all steps then the “default steps” will be getting added back in the web interface.
This is by design in the web interface and its an expected behaviour.
If we dont need IPM steps then we need to disable the IPM activation in the ap system profile.
Version history
Revision #:
2 of 2
Last update:
‎12-25-2017 08:44 PM
Updated by:
Labels (1)
Contributors
